Replacing a piston in 3 and 4 cylinder engines.
jerryjerry05
Re: Replacing a piston in 3 and 4 cylinder engines.
THIN sillycone on the water jacket. The silicone will work it's way out of the Squeeze area.
I put the head on to keep the pistons from comming back out.
I don't "finish" with it till last.You never know if you might have a piston or 4 in backwards?
When I was a noobie.1985 I assembled a block.Took my time and installed all the pistons in backwards:)
