Replacing 1986 Bayliner penta 275 bellows and water hose connector
jmok1978
I have removed my outdrive to replace the bellows and replace the control cable. I noticed the hose connector https://www.amazon.com/Sierra-International-18-2777-Thermostat-Housing/dp/B0000AYZDS was corroded and I will be replacing that as well I am curious if I need to use any type of sealant on the hose connector?
In terms of putting the outdrive on I expect it's going to be a PITA getting the drive slid back onto the drive shaft I'll take any free advice if you have it!
Happy monday!
Happy monday!
no, that little white metal gem will corrode every 2 years regardless of what you do. it is sealed to the pivot tube with the gasket
have small hands to reach in along the u-joints to turn the shaft a bit and guide it in. do not wear flip-flops and drop the drive on your toe (BTDT)
