redgoat
- May 23, 2010
- 102
I am the original owner of a 1967 Sea Ray I/O with a 153 cu. in., 4 cyl mercruiser engine. Recently I had to replace a badly worn water pump impeller that was causing my engine to overheat. I thought I might as well replace my thermostat as I cannot recall how long it's been since I replaced it. My question is does the spring portion fit UP into the thermostat housing or DOWN into the thermostat housing? See photo. It will "fit" either way but I must know conclusively which way it goes before I finish winterizing with antifreeze. Remember this is a 4 cyl mercruiser that has, so I have been told, a Chevy "iron duke" engine modified by Kiekhaefer. I do not want to ruin my new impeller or damage my engine so I hope someone knows which way it goes inside the thermostat housing. I know how the old one was positioned but is it possible I may have installed it incorrectly all these years?
