Replacement Tach Problem
Fish-4-Food
I have a 1978 140hp Johnson. I bought a teleflex tach to replace a older one. Could not get it to work with the wiring harness using the gray wire. So i next hooked it to the yellow wire with grey stripe on the motor buss bar. Tach zeros when power is on but i get no reading when motor is running. Tach is also set on the 6 pulse setting. Thanks for the help in advance!!
