Coastal Rick
- Feb 14, 2010
- 30
Had my 20hp 1973 Merc with a spun prop, and ordered a Michigan replacement 032136. Pulled the old prop and destroyed it in the process, which left the rubber hub and inner metal sleeve corroded onto the prop shaft. Got that all cut off and am ready to install the new Michigan. I've got two questions basically:
There is a shaped metal washer (thrust washer?) that came off between the lower unit and the prop, and it seemed to fit almost completely into the old prop by looking at the wear marks on both pieces. The washer doesn't sit half way into the new prop. Is this a normal situation? The first four pics show what I'm talking about.
Next is the washer and nut that secure the prop to the shaft. It only seems like an ordinary washer, and an aluminum (lightweight, definitely not steel) nut with a funky plastic cap over the top which may be an old school nylock. Seems weird to not have any kind of locking mechanism, but the parts diagrams I've looked at seem to indicate this is the correct hardware. Can anyone tell if this the right parts? Can I simply get a stainless washer and nylock nut to replace the old parts?
Thanks for helping me out!
