Replacement powerhead for 2000 merc 25 2 cycle
JENNIE116LOWE
Anyone know where I can get a replacement power head for my 2000 mercury 25 2 cycle? Serial # 0G983335
carholme
Re: Replacement powerhead for 2000 merc 25 2 cycle
Jennie;
Are you comfortable around a toolbox or do you not feel capable enough to tear apart your existing engine. You would only have to remove the head initially to get a look at the cylinder walls and see how much damage is present.
Your s/n comes up as:
MERCURY - ( 25 H.P. (2000 ))
Serial No: 0G983335 Model No: 1025201WD
Parts List for model 1025201WD:
(20/25/JET 20 SEAPRO/MARATHON 15XD SUPER 15/JET20) (2-STROKE) - Mercury, Mercruiser, Force, etc. Parts Lookup
Service Manual P/N: 90-826883R03
If you wanted to tear it down, I can send you a copy of the manual. It would not be a difficult job and wouldn't cost you anywhere near what the shop was going to charge you.
Gerry
JENNIE116LOWE
I feel comfortable enough to try it, can you send me a copy of the manual Thanks
Don S
Click Here for the manual. When it opens, just save it to your computer.
JENNIE116LOWE
Thanks I'm going to get started. Appreciate your help
Faztbullet
That motor uses the Mercosil block and is boreable if needed....
