When my boat was launched last year it was place into the water with a "Sling". I believe the sling loosened the seam between the top half and the hull. I noticed water coming in through the transom fiberglass when under power at higher speeds. I found some chaulk missing around metal (that holds the bumper guard) that runs around the boat. This covers the seam. My guess is that water travel up and into area behind the bumper guard and traveled down the seam channel and found its way into the boat. So I chaulked the metal to fiberglass where ever I noticed a gap. This reduced the flow, but I am still getting a annoying amount of leakage.<br />The rubber is old and thinned in areas. I was thinking of removing the bumper guard and metal exposing the seam. Chaulking the seam,and then adding a new bumper. Where does one get a new bumper? I am going about this right? ThanKs
