further
- Jun 18, 2009
- 1,034
Wasn't sure if i should post this here or in the volvo forum.... Just received my replacement DB electrical alternator and started looking at the wiring between the currently installed Prestolite and the new DB Electrical and they're totally different. The DB doesn't even have the same # of terminals??? I emailed DB but haven't heard back yet so figured I'd try here to see if anyone has gone through this or could help me out with the wiring as I'm lost....
This is the prestolite
This is the new DB Electrical
I was figuring it would be an easy wire for wire swap out but the labeling isn't even close.
Existing wiring on prestolite is
Orange - labeled "POS+ Output"
Purple w/ stripe - labeled "A.C. Tap"
Green - labeled "Ind. Light Term" (i think, hard to read)
Red jumpered (solo) - labeled "SEN"
Red jumpered with purple - labeled "EXC"
Black - not labeled.
Any help would be much appreciated as always.....
