Re: Replaceing EZ Loader hub, help
Trailer manufacturers rarely build their own hubs. There are many after market manufacturers that it simply doesn't make economic sense to do so. The Northern Tool hubs will work just fine. If you order them with bearings, make sure you have get the correct size. Check the bearing numbers on your existing hub.
