Luckydog_bluey
- Nov 14, 2015
- 1
i have a mercury outboard 45 hp 4 cylinder 2 stroke the motor overheated I strip the lower unit down and fitted a new water pump kit and seals and reassemble and now there is water coming out of the tattle tale only when the motor is in gear and when put into neutral the water slow down and stops until you run it in gear a gain
