Cady8special
- Aug 24, 2011
- 64
I’m at a loss here. Just picked up a boat with 40hp merc 3 cyl 4 stroke. It bogged under load, but did get up on plane once. Any time I gave gas after that it would slow or die. Batteries weren’t charging either, same voltage running or not. So I got a new stater and regulator/rectifier and it still seems like I’m not getting spark in the second cyl. When I spray gas in cyl 1 or 3 it bogs. Cyl 2 there’s almost no affect by it. Same if I cover the manifold and cut the air- cyl 1 and 3 slow down, cyl 2 is not really affected. What else could be causing this issue? It’s not plugs or wires I tested that.
