RickWinslow
- Jun 29, 2017
- 2
Hello all,
I have a 1987 Glasstron boat with a 3.0 mercrusier engine and an alpha one out drive. Serial number on the motor is B456946. I purchased the boat from a friend of mine who let it sit for a few years, and am trying to work out all the bugs to get it water ready. I got the motor running, and am now working on the trim system. I figured out that the pump was the issue (solenoids clicked, and distributed power properly, also tried to jump the motor and got nothing). So i contacted my local marine repair shop, and had them order me a motor. The old one was a metal cased square motor. The new one he sold me was supposed to be the newer replacement, and bolt right to my pump. It does, but the problem now is that the plate that the solenoids mount to cannot screw in properly to the top of the motor, like it did to the old motor. Because of this, I can't ground the plate onto the pump properly. I tried to run the ground directly to the plate, but that didn't work either. I get just under 1v when the switch is operated. I tried putting the old motor back in, and while the motor didn't work, the solenoids both put out the proper voltage when the switch was activated. I'm at a loss, and hoping someone else has a solution to my issue. Thanks.
