I just completed a swap of a lower unit on my Alpha 1 Gen 2 sterndrive as was told by a tech that my issues with shifting into reverse where due to a worn clutch dog. My lower was pretty beat up, so I picked up one from Marine Parts Supply in MS. They rebuild the water pump and leak test them before shipping.
I went through and followed all of the guides that I found online, everything went pretty smoothly after getting the old one off. Filled with gear oil, fired up, plenty of water out of the exhaust and no real leaks that I can see.
I did notice while the boat is on the trailer, not in gear, but running, if you push slightly on the bottom of the lower housing, you can feel almost that something is rubbing or coming in contact with the inside of the lower housing. Is this normal? What could be going on? I am concerned about running it if there is something that could be loose in this new lower.
