I am wrapping up my head gasket replacement on my 1997 Mercruiser 3.0LX & have a question about rocker adjustment. I haven't figured out a good approach for turning the engine other than using the starter. The problem is that i need to get the thing to TDC in order to set the rocker tension. The starter is an imprecise way to do this for sure. Any thoughts on a better approach? Thanks in advance! The outdrive is an alpha one
