Replaced gauges but now the voltage is all messed up.
BrettUmd
I just replaced all my gauges on a 1995 Proline with a 90 hp Johnson. After I finished replacing the gauges, everything worked perfectly, but I forgot to hook up the light on a new compass that I bought. I was looking for a way to connect the compass to the lights on all the new gauges (so when I turn the light switch on, the compass light will turn on with the rest of the gauges) so I spliced the positive into the wires that the lights run on (the wire was blue) and connected the negative to a ground under the dash (I connected it to the same ground as the ignition). The light on the compass never came on, so I disconnected it and put everything back as it was before I started to mess around. Now the voltage meter doesn't work, the trim gauge doesn't work, and smoke comes off the purple ignition wire when the key is left in the on position. I spent nearly 2 hours looking at all the connections under the dash, and everything looks fine, but the gauges are still screwed up. I am beginning to think that the ignition could have been fried, but the engine still cranks when I turn the key so that theory may be out the window. Any ideas? Thanks in advance!
D
DJ
Guest
Re: Replaced gauges but now the voltage is all messed up.
Yikes!<br /><br />Look for a fuse under the hood of the engine.<br /><br />I think you shorted the ignition to positive, with that set up.
moderator1
I'm going to move this to Boat topics and questions for now..We don't really have a broken engine...yet. :)
