capecodtodd
- Aug 11, 2010
- 128
I finally wrapped up replacing the bellows on my 1998 3.0 Mercruiser alpha1 gen 2 out drive.
Replacing the shift cable bellows required me to pull out the cable. That went back together easily but now when I shift into forward and turn the prop by hand it is skipping and a clinking can be heard from inside like the gears are not engaging. The same thing happens in reverse.
All of this testing is being done by hand without the motor running. The shift was put in forward when the outdrive came off and the 2 pieces married back together where they belong now.
What is odd is my manual and what I have found on line says that between the hole on the shift sleeve that goes to the motor and the barrel should be 6". Mine is more than this by an inch+. I tightened it up getting it close to 6" and I could not shift at the helm. I loosened it up past where it was and the gears were not engaging at all.
I really hate to have to pull the outdrive off again to check the end of the shift cable but what else can it be?
