1994 Chaparral with 5.7L merc and Alpha I Gen II sterndrive. Engine and sterndrive are original. My exhaust bellows has a rather large hole in it, and my trim and limit switches both do not work (they are frayed at the switches on the upper unit).
1. Do I need to replace it, can it be done easily, or does the sterndrive need to be pulled?
2. If I tear into it, what else should be replaced? Shift cable, exhaust bellows, bearing and ujoint (no idea what shape they are in, I will assume they need replacing)? I did the impeller last year, so it should be ok.
Thanks
Thanks
