Replace two oil seals on propellor shaft directly behind the Prop on Suzuki 175
whitecbas
I this will be my first attempt to replace the two propeller shaft seals behind the prop on my Suzuki df 175 engine . I believe I need a seal puller tool also do I need to do a pressure check . I can and do the water pump impellor install , how does this job compare ? Is this a very technical procedure ,if so should I take to dealer. They are so backed up now and I need to go catch something!
lawcki
I just have this done at the dealer on my 2001 250 TXRZ. He had to pull the prop shaft with a puller and a 6 Lb slide hammer with an aid of a large torch. No chance of pulling out just the bearing housing alone. Good luck.
