replace new hubs
phatmanmike
high i have a small john boat trailer, about 14 feet long and 5 feet wide, wighs about 150lbs, and one of the hubs is locked up. this is new to me, trailer hubs that is, how can i replace the hub or how can i just make it roll without squeaking really loud. it is so stuck that you cannot moove it by hand, must be moved by vehicle<br />thanks<br /><br />mike, again
JB
Re: replace new hubs
Ahoy, PMMA<br /><br />Your bearings have siezed in that hub.<br /><br />At the least it will need new bearings and races, maybe a new hub, too.<br /><br />While you are at it replace the bearings in the other hub as well.<br /><br />Grease the bearings thoroughly and put bearing buddies on both.
lakelover
Thanks,Bondo, this is exactly what I needed to know for one of my spring projects :)
