Replace Heat Exchanger End Cap
acicomp
I've been working through the systems on the boat to get it ready for water. I noticed a drip coming from the end cap of the heat exchanger, so I pulled the caps off the exchanger today and found a crack on one of the caps. At an initial glance, I thought this would be a 4" system, however, when I measure the cap, it appears to be a 3.75" cap. Being new to the boat world, so to speak, I thought I would ask some folks more knowledgeable than myself. The boat is a 1982 Renken 995 with a 1982 Mercruiser MCM120 (2.5L) motor. This looks to be a possible aftermarket exchanger by the way it is installed. It's strapped to the stern wall on the starboard side of the motor. Can anyone recommend what size caps/gaskets to order for replacement or part numbers I might be able to use here?
Thanks for any help.
Ayuh,.... That's gonna make it tough,.... San Juan has alota units out there,...
Any other identifyin' marks on it anywhere,..??
acicomp
No Title
Found the tag on the back of the exchanger. It's a Sen-Dure 4987-1-5. Looks like they are still in business, so I may try to call them tomorrow to double check.
FreeBeeTony
I don't live far from there, Bayshore, NY, and don't think they are around anymore............sorry.
sen-dure is still in business. the end cap is brass, can always clean it up and have it brazed (that is what I would do). it is a standard 4" end cap shell of your heat exchanger is 4-1/8", the spider casting sits inside, and the end cap is about 3-3/4" like you measured.
acicomp
Thanks for the info. I thought it looked like they might still be open. At least their website was still up and running.
acicomp
I called Sen-Dure on Monday and got the part number for their end cap. It comes as a kit with new cap, gasket, washer and bolt. They recommended I order from Defender, so I called them up and ordered one for each end to have them both right to start with. Parts arrived today, so I will be installing tomorrow and getting one step closer to finally getting her in the water.
