I have a (new to me) 1977 Formula 233 with MCM 250 with an Alpha drive. The motor is freshwater cooled from a thru-hull fitting: no water comes from the outdrive. <br />The exhaust bellows is leaking water into the boat. The boat is currently docked in freshwater at my house while I "shake it down" prior to going to a mooring in salt water next week or so. I have read about the procedure at mercstuff.com where the gimbal ring must be removed to replace all of the bellows. But can I replace just the exhaust bellows without removing the gimbal ring? It looks possible if one could get a screw driver to tighten the bellows at the transom side. I don't want salt water sloshing around in the bildge and spraying the motor and accessories. Also, is there a difference bewteen a pre-Alpha gimbal housing/transom assembly and an Alpha assembly??<br />The outdrive is a new Sierra unit.<br />Thanks<br />John
