Replace carb floats during rebuild?
mitchbuck
Last year I rebuilt the carbs on my 1990 90-hp Force using a carb rebuild kit that included everything except the floats. Was it a mistake that I didn't replace the floats as well? They floats look to be made of a black foam but didn't appear to be deteriorating or water logged.
pnwboat
Re: Replace carb floats during rebuild?
As long as they are working correctly, they should be fine. Finding replacements can turn into a frustrating experience. Don't ask me how I know. LOL! You know that old saying...If it isn't broke...don't fix it.
gm280
Can't say one way or the other not seeing them. But I make it a habit to NOT replace working parts...
jerryjerry05
Most time a carb doesn't need a rebuild.
It just needs a good cleaning.
Making sure the jets aren't clogged.
The needle/seat is in good shape. No grooves.
The air screw no grooves or scoring.
My carbs are 26 and never needed a rebuild, just a cleaning after setting for a long time.
Jiggz
You're good. That black foamy like float is actually tougher than it feels or weigh. Unless, it is obvious that it is deteriorating with the presence of black sand like grains in the bowl, there is no reason to replace it at all.
mitchbuck
Thanks for the input guys!
