Replace 6000LBS Surge Brake Actuator With 7000LBS Model?
dingbat
Typically just a larger actuator displacement.
Couldn’t hurt if your pushing limits with a 6k.
How much does the boat weigh?
sam am I
About 3200LBS w 175
82 Gal Tank (8*82) 656LBS
Trailer Single Axle Escort 25' 500LBS?
Gear/Beer 300LBS
So maybe around 5K Total
Wasn't sure if the because the 7000LBS actuator was rated 1000LBS higher than the stock 6000LBS old one, would it perhaps not engage/assist as much.....Couldn't find a replacement in same style as the old 6K, so got the 7K because it WAS same style as the old one, wasn't really thinking I guess.
bruceb58
Doesn't matter. The surge brakes are self regulating which means that the brakes are applied until the trailer is just pulled back from the master cylinder. That's also why you can have a completely empty trailer and they work fine then too.
