Hello all, I am trying to repair my bunk rails. One of them needs new mounts and they both need new carpet. I have a cherry picker and was going to run a strap around the entire hull under the engine and lift up the boat, but the boat is resting on the bunks and i cannot get the strap under it.
Can I hook it to the transom tie down rings? or should I wrap it around the outdrive close to the transom?
Or is there a much safer better way?
I cant really put the boat in the water and then work on the trailer...
Thanks!
Thanks!
