Repair or Replace?
rdxgator
2003 DF90; water does leak out but doesn't appear to be mixing with the oil.
Thoughts on trying to have this cracked repaired or does the block need to be replaced?
robert graham
Re: Repair or Replace?
I can't imagine that crack ever getting any better...only worse! Maybe saltwater has corroded it through from the inside? You can patch it or JB Weld it, but it would really worry me!...I think it needs to be repaired or replaced, and either way gonna cost a lot$$$ Good Luck!
