My old evinrude 140hp outboard from the middle 1970s broke. It overheated once and I changed the water pump. I took it out for the first time after the overheat a couple of days ago and it would shut off before I got the chance to move the throttle. then it started to make a grinding sound and would not start anymore. I later dicovered that one of the spark plugs is smashed an you can see the piston right against the plug hole. I figured it snaped a piston rod and I might need to change the rod, piston and some other parts. I can do most of the work, but I'm trying to figure out if I should just scrap it and buy a newer one. Money is an issue... I'm trying to go for the cheaper...
