Repainting my 74 Johnson 9.9 Seahorse?
Edrosytoe
I need advice on how to sand/ & repaint my outboard engine to a nice SHINY, metallic black (I could care less about retaining the original color). I would like to know:<br /><br />1). Suggestions for any specific type of fiberglass/ & metal paint needed for an outboard?<br />2). Decals needed, Or should I just get artistic?<br />I already used tracing paper to carefully emulate the decals.<br />3.)Lastly, I WORK 7 DAYS A WEEK - I MIGHT JUST DECIDE TO HAVE A REPAIRER DO THIS TASK FOR ME - ANY SUGGESTIONS FOR A "REPUTABLE" REPAIRER IN MY AREA (North Babylon, NY) :rolleyes:
Code:
JB
Re: Repainting my 74 Johnson 9.9 Seahorse?
Hi, Ed.<br /><br />Welcome to iboats. :) <br /><br />I will move this to the General Outboard Discussions Forum, where it will get the right attention.<br /><br />Good luck. :)
petrolhead
I do this sort of work all the time, unfortunately I'm not even in your country let alone your area though!<br />For the fibreglass parts you should really use a 2 pack polyester primer, and for the metal either an etch primer like zinc chromate, or I prefer 2 pack epoxy primer.<br />The best topcoat is probably a 2 pack acrylic. <br /><br />The problem is that none of these products is really suitable for home use, and if what I hear is correct may not even be legal for home use in the US!<br />Go to an auto body repair shop and get some advice, they may be prepared to do the work for you for less than you might imagine, and will almost certainly do a better job than you can.<br />It may even work out cheaper as they will have most of the materials already, saving you buying more than you'll use.<br />You can probably save some money by doing the preparation work yourself, removing old paint and sanding to a smooth finish ready for the new paint, that's what takes the time and costs the most.<br />I find an electric drill or an angle grinder with a wire brush gets the worst off without chewing up the metal castings, but don't use it on the fibreglass!<br />You can then use sandpaper, but don't get the surface too good as some slight roughness will help the primer to adhere, a couple of coats of primer will fill the sanding scratches, and most modern high build primers need little or no preparation before the top coat is applied.
Edrosytoe
Hi<br /><br />I did'nt really think that my small problem would get an answer, But then YOU answered.<br /><br />Thanks!!<br /><br />I really do appreciate your answer. ;)
petrolhead
Glad to be of service! I hope it's of some use to you. I like it when someone asks a question I know the answer to, makes me feel useful!<br />I'm in the process of repainting my '58 Johnson 18 right now, this is a complete bare metal respray in original colours. I love doing this stuff, very satisfying when it's all finished and looking brand new.
