Re: Removing Vertical Drive on OMC Cobra
Sloop,I also have a cobra on both my boats and have removed the out drive several times for service, they are a breeze, remove 6 locking nuts and washers and pull it off. Reassembly is a little more diffacult as the upper boot and the u-joint yoke fit very snug with each other. If u don't have a lift u will need another pair of hands,one to hold the outdrive in position and the other to help alien and rotate back and forth the u- joint yoke through the boot, make sure this yoke is strait with the boot, if not, u will damage the boot thus causing it to leak threw the gimble.BOOT 58 BUCKS, and u will need a new gasket set for reassembly,6 bucks. As far as the drive being in gear, I have always had mine in neutral. I know they reccomend the mercs to be in gear upon reassembly but I think it is easier to rotate the yoke with a screw driver when I am in neutral and I have never had a problem ..good luck
