Re: Removing thrust nozzle
its pretty simple bro. I woudlnt sweat it.
You can pull the whole pump off. Disconnect the trim and steering cables and then unbolt the 4pump. Pull the whole pump off to give yourself some room to work. then put the whoel thing back on. you may need some silicone where the syphon tubes and the water supply hose go through the hull but I think on later models its not applicable cause they changed the design. so you may not even need to do that. hey youll have a chance to service the pump also.
