I have a 1991 Johnson 200hp. I have to remove the lower unit to change the water pump. The problem is that when all the bolts are removed, the unit will not drop down. We put some pressure on it and it did drop down about a 1/4 inch. <br /><br />Any suggestions on how to get this off. I'm trying to avoid cutting the drive shaft. Any ideas would be appreciated.
