removing the bearing housing assembly
knboat
so i have a 1993 115hp evinrude and i can't seem to get the bearing housing out. i took the four bolts out and got a puller on it put pb penatrating oil on there and still nothing any ideas or is there something more i have to take off?
Joe Reeves
Re: removing the bearing housing assembly
With a hand help propane torch with a blow torch tip, apply heat to the outer ring area and also to the inner "O Ring seal ring area. Those two areas are prone to corrosion.
bob johnson
dont you have a big snap ring in there????
I know many lower untis had one or two huge snap rings holding the carrier in, on my 95 115 they just had a few bolts and retainers...
Take a look down in there and see if you see the holes in the snap ring!!!
good luck
bob
boobie
The snap rings hold in the plate that the four bolts go into to hold the bearing carrier in. As long as they are out, use a good puller and plenty of heat.
knboat
don't think this motor has snap rings. if there is i don't see them
bob johnson
post the exact model number and the BRP exploded diagram will tell us if you have them or not!!
actually you might have them, but you dont need to removed them until after the carrier is out....
which is either 2 bolts up front or four bolts down deep.
so you just got to work at it some more...
good luck
bob
boobie
If you took four bolts out of the carrier you will find some snap rings.
bob johnson
is it a consensus then that the carrier comes out before the snap rings do??
i think that is the jist of this thread...
hopefully i didnt mess up the OP too much!! ha ha ha
bob
knboat
finally got it talk about a pain in the butt. heat oil and some good old elbow grease. thanks everyone
boobie
Yes. Pretty hard to get the snap rings out before removing the carrier bearing unless you know something I don't. LOL.
