rhartSilverdale
- Aug 29, 2003
- 15
Hello,<br /><br />I have a 1985 3.0L 140 OMC I/O (non-Cobra) in a 1985 Bayliner Cuddy with a fixed trim. I am thinking of removing the stern drive in order to remove and repair the tilt mechanism. Apparently, the tilt end cap has a split in the o-ring seat rail which cause the o-ring to not seal properly. It leaks water into the tilt housing to the point that there's only water and a lot of gooey tan sludge. The drive is now stuck in the down position. I took the tilt motor out and tested it, and it spins with good torque in both directions. So unfortunately, I'll have to remove the stern drive in order to get to the rest of the tilt mechanism.<br /><br />My questions are:<br /><br />1. Is the stern drive a very heavy unit - will I need a hoist to manage it?<br /><br />2. According to the repair manual, in order to remove the stern drive, I will have to tilt the stern drive up slightly to gain access to some bolts and things. However, since the tilt drive is not working, how would I tilt the stern drive up? I've tried lifting it manually, but it won't budge. The manual doesn't say anything about this. Any suggestions?<br /><br />3. Finally, does anyone know where I can find some replacement parts for the tilt unit; i.e. end cap, gaskets, etc.? It appears that this stern drive is considered obsolete.<br /><br />Any advice will be appreciated.<br /><br />Thanks.
