removing seal glands seastar
mistylady
I successfully removed the defective gland on the port cylinder, cannot budge the starboard side. used a heat gun (could not use a torch to much light and wind) any suggestions? ps the starboard side does not leak, however i do belive in murphys law.<br /><br /> mistylady
JB
Re: removing seal glands seastar
What engine, mistylady? What was the problem?<br /><br />If you posted on this trouble before you need to reply to your original post and bring it to the top of the forum so readers will have some idea of what you are talking about.
mistylady
I have a mercury single outboard with front mount seastar hydraulic steering. the seal glands are located on each side of the hydraulic cylinder. I removed the port side which was defective and replaced the seal, the starboard side wont budge. Since thet sell as pair i thought it best to replace both sides. any body have any suggestions?<br /><br /> Thanks<br /> Mistylady
