removing programs
eurolarva
I am running windows XP with service pack 3 on an 8 year old pc. In the add remove programs there are multiple titles with different rev numbers like J25E runtime enviorment 5.0 with updates 6,9,10 and 11. Can I delete 6,9 and 10 and just keep 11. Same with Java (TM6) updates 2,3,5 and 7. Can I remove 2,3 and 5 and just leave update 7? These are all rather large programs. The Javas are 114 megs each and the J25E are around 120 megs.
i386
Re: removing programs
It may break them if you remove them. If it does you should safely be able to remove them all, then install the latest one.
I currently have:
J3SE Runtime Environment 5.0 Update 11
Java(TM) 6 Update 3
Java(TM) 6 Update 5
Java(TM) 6 Update 7
Java(TM) SE Runtime Environment 6
Java(TM) SE Runtime Environment 6 Update 1
On my system, I would not be afraid to remove all of it and just wait until something tells me I need it. All my stuff that uses Java is working so I think I'll just leave it be.
Bob_VT
What size hard drive? 115 meg is actually very small by todays standard. It would fit on an floppy disc.
I would just leave them in place.
eurolarva
Hard drive is 37 gig with 20 gig available.
