Removing powerhead from 2005 Johnson 3.5hp
yeter
On my 2005 3.5 hp Johnson no reverse outboard the gear lever has become very hard to move and I want to remove the powerhead to see what the problem is. Can I remove six bolts and pull it off? Do I need to remove the gearcase from the midsection first? Any help would be appreciated.
Peter
Sea Rider
If pulling powerhad out will need a new base gasket as old one will be shot and irrecoverable.
Happy Boating
Vic.S
Peter
I believe you can pull the power head without also removing the gearcase but unless its been changed recently why not renew the pump impeller at the same time
hardwater fisherman
When reinstalling the power head, you will need to insert the cooling tube in the water pump and or the power head. That would be pretty hard to do if the gearcase is not off. Also there might be shift a linkage to deal with.
jakedaawg
I don't work on the little ones but...
I would start by pulling the lower and seeing if you can shift it by hand easily.
The problem may not be in the gear shift linkage at all
Vic.S
The problem will almost certainly be the shift lever shaft where it passes through the top of the exhaust housing to connect to the bellcrank and shift rod.
There no grease nipple on the 3.5 so the lever gets stiff then seizes and gets broken off if not freed up.
jakedaawg
Good to know, thanks.
