Re: Removing / Plugging a Livewell Thru-Hull?
Okay, so here's what I started today. I went with an off-the-shelf solution, rather than trying to fabricate anything as I'm not really equipped for that. There are 5(!) holes in the boat to fix...
- Removed the 2 livewell pumps that were mounted directly though the transom, and bought 2 marelon thru-hulls of the same diameter- 1"
- Removed another pair of through-hulls (3/4") and their hoses.
- There's one more through-hull that takes a 1 1/4" hose that also ran to the stern livewell. I removed that hose and pulled out the fitting.
Each matching pair of fittings has been/will be reinstalled with a bead of 3M 5200, and a new hose and clamps used to bridge them together. The 1 1/4" through-hull doesn't have a mate, so it'll be reinstalled with 5200, a new piece of hose and clamp, and a clamped plug at the end of the hose.
The old fittings and hoses were still intact after 17 years, so I figure this'll be fine. Thanks for the ideas- gave me a lot to think about.
