I am stumped.
I am replacing the glue-on pads for the Weaver davits on my hypalon RIB. I have removed the old pad with gentle heat, a little MEK solvent and much colorful language. Now I need to prep that areas for the new pads by removing the remaining glue residue. I can't find a solvent (that I am willing to take near hypalon) that will even touch it. Goof Off, OPPS, MEK, Gasoline, Alchohol, WD40, lighter fluid, carb cleaner, brake cleaner. Nothing even makes a dent in it. I acquired the RIB with the davit pads installed, so I do not know what type of glue was used.
Does anyone know of a magic elixar that I might try?
Many thanks
Many thanks
