hckrphil
- Aug 8, 2004
- 162
I have a 94 Mercury sport jet 90hp engine that I'm going to rebuild myself (after the run in with the awful backyard mechanic that messed up the block).
Anyways, initially it needed a rebuild because it lost pressure in the middle cylinder.
The ring on the piston was broken. The engine has oil injection.
The reason the 2nd cylinder failed (I believe) is because the oil line shooting into that cylinder was plugged! I don't think it was properly being lubricated.
Now, if I wanted to remove oil injection from this engine, can I just pre-mix my gas, and remove all of the little rubber lines running around the engine? Or do those lines have another purpose?
I've unplugged it now, do you think I should KEEP the oil injection......... or just remove it and premix.
Once I get this engine all back together, I'd hate to have it fail again....
Thank you!
~Phil
Thank you!
~Phil
