Removing lower unit
baconbiscut
I finally figured out what year engine I have. It's a 1964 Mercury 200 20HP. i got it to run in a bucket and it ran alright the points probably need to be sanded and gapped. Well i'm an OMC guy and i'm not use to the whole Mercury thing and I wanted to get some info. While running in the bucket it was not pumping any water. So i shut it off. I then realised there are no bolts on the LU well how in the heck do you get it off and also how should the waterpump be changed I should also change the seal as there was water in the LU when I drained it. i refilled it with Mobile 75W-90 GL-5 gear Lube. anyways any instrutions on removing the lower unit would be great and i would also like to know about any kinks with this motor
Thanks Much, Dan
