REmoving lower unit to replace water pump
jsmoak
89 evinrude 40hp el. where is the shift rod connector located. I have removed the 5 bolts, but cannot locate the shift rod. Also what is the correct adjustment measurements? Have just bought the motor and have no manuals.
rwcreigh1
Re: REmoving lower unit to replace water pump
trust me get a manual.try ebay they are not that much.remove the little black screens on the sides of the lower unit and they should be there(they are on my 84 35hp)they may be under the carb.good luck
Walker
Its either just below the carburator or behind the water intake screen on your lower unit. I agree, a manual is a must and will pay for itself easily.
jsmoak
Thanks to both of you. ERN41 posted what sounds like the same problem on 3-24-05. It seems that moving the horizonal shaft on the power head may be the answer. Manual has been ordered.
