Re: Removing Lower unit Suzuki 4 hp?
Are you sure its a zuki ? You can get the parts breakdown from brownspoint.com you'll see the clamp in the lower leg drawings. If its dropped three inches its the only thing that would allow that much movement and still not come free.<br />I've got the old rusted out powerhead in bits in the garage and the piston is completely jammed. <br /><br />On the sides of the block are two covers about 2 inches long and 1 wide held in place with a couple of small bolts. These are the transfer covers for the intake . The seals underneath are rubber "o" rings. Remove these and you should be able to see the condition of the rings and the side of the piston. Soak it in some penetrating or 2 stroke oil. If its rusted up you'll be able to tell from there as rust wil wash out. Can you tell if the piston at TDC or BDC , if its seized at either, the flywheel movement is just the con rod rotating on the piston pin and its likely the whole thing is solid. <br />If you want to get extreme you can get a 1/2 inch socket extension bar in the spark plug whole and give it a few taps. If it still wont move time to tear it down. Let us know how you get on. If it all turns to custard I'm after some parts anyway.
