Hey all I am new to these forums and have a question. I have picked up a 1970 Johnson 9r70c 9.5hp motor and want to replace to impeller/water pump. When attempting to remove the lower I have taken out the 4 screws and disconnected the shift rod. Now in the manual it says there are 4 different ways to drop the lower unit and I cannot figure out which method I need. I have tried to rotate the flywheel clockwise to line up the pin but have had no success doing this. So i guess my question is do I need to remove the powerhead to disconnect the driveshaft? I am just trying to figure out the simplest way to replace the impeller. Thanks in advance!
