removing lower unit on 77' johnson 85hp
1st Timer
can get everthing lose but the stupid gear shift linkage. Can't tell where to unhook it from, or if it just takes a couple real good yanks to get it to come off. please help..
D
DJ
Guest
Re: removing lower unit on 77' johnson 85hp
1st. Timer.,<br /><br />It's ALOT easier if you put the engine in reverse first.<br /><br />The shift linakge disconnect is located under the bottom carburetor. Just romove the bolt and the linkage shaft will slide out with the lower unit.<br /><br />It's tedious to get at, just be patient.
1st Timer
Thanks djohn19, I wasn't to sure if that was were it had to come out from or if there was some where lower than that, that it could break apart at. Thanks again.
