Removing lower unit house bearing?
Stickalip
1994 Yamaha 130TXRS
Near the water pump Im trying to remove the house bearing to replace seals.
I removed the 4 bolts and the top seal came out easily but the other seal requires that the housing is removed. I have tried PB blaster and heating it a little.
Is there a special tool required..tricks?
I'd appreciate any advice
99yam40
You might need to explain what you are calling a house bearing
Capt Ken
He's trying to remove the carrier that holds the upper bearing. Held in place with 4 bolts. You have to use two screw drivers, one on each side and slowly work it up. If it's corroded in, you may break it if not careful.
