Re: Removing lower unit... hiddin bolt?
Here are my answers to your questions:
1) I got the Prop from Phil's Prop Shop. It is listed on Turningpoints website. Call him up and he will give you a good price. I got the 13 1/4" X 17 pitch for my boat, it seems really good to me. The prop that I currently have is the Aluminum Hustler from Turning point Prporellers. You can find it here:
http://www.turningpointpropellers.com/hustler_aluminum_propellers.php
You can contact Phil's prop shop from:
http://www.boatpropsrus.com/ Give them a call for a price, but for that prop and system it should be about $100 or less.
I have just ordered this past monday the new Stainless Steel one, in the same size listed above, the Turning Point Express. It ran me $170 from him, it was an older model and not the new hub design as shown on their website, but I don't care. For the Price, I couldn't beat it.
This prop made a huge difference as to how it handled in the turns, without cavitating.
2) I got the Reeds from Boyesen:
http://www.boyesen.com/outboard
They are $126.65 here is the LInk to the part that I purchased.
To install them you just have to remove the Carboretor and the Mount that is on top of the Block. Its not hard at all, if you already have the carbs off, it is very easy. They made a huge difference in the way my boat ran. Between these and the Hustler Prop, my boat would jerk me out of the water, 200lbs, on the wakeboard. Before I would have to lag back and get dragged by the boat until it got up to speed to get me up out of the water.
3) It is possible that the Rubber grommet and metal piece might be stuck at the very top of the shaft, not sure about that. On mine, they were hung up and then fell out of the engine on the driveway. Also, when you put it back together make sure you Grease the Splines good at the top of the shaft.
4) On the lower unit gear oil there is a drain plug at the very bottom of the Unit. On my engine, It is a hex head screw that is seated down in the unit. It is on the bottom of the point on the opposite side of the Prop. Undo this, then you can drain the rest of the fluid. Try some PB Blaster or some other type of Penetrating oil, to get that screw to come loose. This is the only way that you can drain all the oil out of the unit. I usually open this screw and then flush it with new fluid and try to get as much of the old crap out as possible.
5) Not sure about the Prop spinning freely, if I spin mine by hand it will do a few (2-3 maybe) revolutions, but not many. It seems kinda tight to me, but it is fine when I am driving. Not sure if there is anything to do in there to fix this or not. I just change the lower unit fluid yearly, or twice a year depending and I've had no problems for the 9 years I've owned and run the boat.
Also someone on here had told me to run a certain spark plug for that motor. The one that I have been running since I was told this is the NGK BUHW, this is the only plug I run and it works great compared to others I had tried in the past for this motor. I get these are Carquest or Napa, I think they both have it. I always get them from Carquest as it is close to me.
Hope you get this engine back in the water. If they are taken care of they will do you right.
Bryan
