Seanmccullar
- Jan 2, 2016
- 28
Hello. I recently purchased a 1957 johnson seahorse 35 hp RDE-19. I have never worked on an outboard (or engine for that matter) but purchased a cook service manual with the intent to tear this down, paint and rebuild the motor (very aspirational!).
My first problem is removing the flywheel. I removed the nut from the crankshaft and have used the pictured flywheel puller. I have put as much pressure on this as I can (including penetrating oil) but it won't budge. Am I missing anything? Is there another bolt to remove? I am starting from scratch here, so assume I really don't know anything.
Thank you.
Sean
