Jim Robbins
- Jun 15, 2005
- 85
1973 Mercruiser 140 hp (Gm - 4 cyl. ( "The Iron Duke" I think that's what they call it)
The previous owner removed & covered up where the fuel pump was and installed an electrical fuel pump. I want to return to the original type fuel pump, I have one ready to go with a new steel line to the carb., so I think I'm all set there.
My question is, I mentioned what was done to this motor last year on this site, and I was advised to have an oil pressure sensor installed, incase the motor was operating with out proper oil pressure, then o.p. sensor would turn off power to the electrical fuel pump and the motor will shut down before damage.
Now that I'm going back to the way the motor was built to run, can I remove this oil pressure sensor? Do I need any-thing else? Can I use teflon tape on the fitting threads?
I was also planning on mounting a fuel filtering system between the tank and the fuel pump, is this the correct plan?
