Removing carpet from 2004 Tahoe Q4 SF
fdtiger
I am looking for some advice. My wife and I recently bought a 2004 Tahoe Q4 SF. We love the boat, but I don't really like having carpet in my boat. We spend a lot of time tubing, and I have noticed that the carpet gets really wet.
So, I am considering taking the carpet out of the boat. I know the the newer tahoe boats come with snap-in carpet. My questions are:
1. What does the floor under the carpet look like? (Is it an unfinished surface)
2. If I take the carpet out, is there something I can put on the floor to make it slip resistant?
3. Can I do this without a lot of costs?
I am not the most mechanically inclined person, so I appreciate any advise you can give.
Fireman431
Re: Removing carpet from 2004 Tahoe Q4 SF
Your boat is new enough that the floor under tha carpet should be finished gelcoat with a textured surface. The surface is usually molded in from the factory. Lift up a small portion under a seat or under the foot rest of the dash & check it out. Maybe under the engine shroud (if I/O).
Your carpet may be glued in place, so be prepared to either glue it back down of have some solvent ready to get the glue off of the floor.
fdtiger
So I checked under the carpet and it is plywood. Now I am thinking about taking the carpet out and either using Durabak or having Rhino spray it. Any suggestions.
bear_69cuda
Good day,
I did the same thing on my Bayliner... You can check out the results in the link below my signature line... Durabak is a great product. I would use one coat of texture and top with 1-2 coats of non-texture... My Hurricane came with snap-in carpet.. I removed it the day it came home, put into storage, and never plan to install unless I sell her...
Good luck!
