Re: removing a lower cowling...
Should be 4 bolts holding it together. Look on the rear through the clamps, down lower under the pan, on the front through the clamp and another in front right in front of the mid-section. And then there will be a spring clip on the alignment studs inside the pan on each side. Just pull the clips off.
