ive managed to get those darn ring clips out, took 2 days, a hanger, small needle nose pliers 2deep sockets and extensions. im reading my manual and it says i have to remove the pinion gear to remove the prop shaft and clutch/shift mech as a unit. they say use a socket but i only see room to fit a wrench what size is the nut? also i dont have the driveshaft spline tool(does anyone know where i can get one?) or an old crankshaft to use to hold the shaft.Would a large vise grip work? i was thinking of cutting a slot in the shaft to fit a wrench.as for bearings, how would i get the inner bearing out of the bearing housing,its the bigger one where the o-ring is.and changing the shift shaft o.ring,how is that done?<br />thanks for the help<br /><br /> http://www.network54.com/Forum/message?forumid=91557&messageid=1110830629
